If its a rotary Cav or Bosch it does not have a mechanical override to start as the solenoid is spring loaded to shut the fuel off when the key is off,if you have power at the terminal attach a test lamp,key on the lamp should light,watch the lamp and hit start,if the light goes out there could be a problem in the ignition switch,use a jump wire then directly and see if it starts,if the light remains on remove the solenoid,be careful not to lose the plunger and spring,put the solenoid back without the plunger and spring and try to start,if its starts you need a new solenoid,if its a Cav pump it will have a mechanical stop lever to the front of the throttle lever that can be used to stop the engine,if its a Bosch you will have to stall it.
Today's Featured Article - The Day Mom Drove the 8N - by Brian Browning. My Dad was wanting to put in a garden but couldn't operate the 8N and handle the old horse drawn plow he had found and rigged up to use with the tractor. Well, he decided to go get Mom out of the house and have her drive the tractor while he walked behind the plow. You got to understand that while my Mom is a hard worker who will always help whenever she can... she had never operated farm machinery before that day. Dad got her out there, explained how the clutch was the same as in our o
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
