Crawlers, Dozers, Loaders & Backhoes Discussion Board
Does water and hydraulic fluid seperate after setting awhile
Posted by chuckinnc on April 17, 2013 at 01:24:03 from (198.135.207.175):
I have a old Ford 4500 tbl that had water in the
hyd fluid. The 4500 has been setting for over a year I was thinking of pulling the bottom hyd drain plug and letting some of the water drain out before I
crank it again. Does this idea make sense?
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that’s wha ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
