You have the later type adjuster, could not recall, but 17A's must be where those started in '55 or so. Sounds like a typical track toss event & solution. I believe you are correct on track tension, should be about that when pried up from the carrier roller 1 1/2"-2" Probably also glad you did not split the track, once you get some relief on the track frame, by jacking or raising like Wayne said, then its a matter of being able to manipulate the track with what you have, certainly nice to have a tractor with a loader or backhoe, we had none of those and still got it back on after a few attempts. Like you said, I hope to not have to deal with that again either !
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
