If your machine has the Borg Warner Velvet shift shuttle with a manual shift and clutch cutout that the valve needs adjusting, the light is for the shuttle oil temperature,check the oil level with the engine running on low idle,the gearbox in fourth gear,the shuttle in neutral.if the level is good check that the lines going to and from the cooler are not kinked or squashed,see the cooler is not blocked,get a second person in the seat and go underneath in front of the left back wheel,look up at the side of the shuttle and get the helper to move the F/R lever so you can see if its moving the valve and press the clutch cutout pedal,you will see the lever moving away from the valve and the valve plunger coming out,when the plunger is out drive is disengaged,it is spring loaded to disengage,when the pedal is released the linkage should push the plunger back in to within .010" of bottoming,there is a bolt with a jam nut screwed into the plunger to set the adjustment,first jam the plunger all the way in to see if drive is restored,do not use force,there can be other causes,torque,pump,etc.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
