Posted by Case450 on February 15, 2013 at 12:30:05 from (67.58.216.98):
I installed a master switch between the positive battery terminal and the starter solenoid on my Massey Ferguson 470 wheel loader because the battery would trickle off and die. While removing the battery cables I noticed the rubber sheathing that coats it was brittle and cracked. I then cut a heavy gauge jumper cable to replace the battery cable. I welded the switch mounting plate, installed the switch, installed all new connectors and tightened everything down. While all this was happening I had the battery on the charger. When I put the battery back in I noticed it was fairly hot. The entire battery.
I put the voltmeter to it and it read 12.18 volts. The master switch works properly.
I am thinking this battery is a done deal on account of it not taking much juice but specifically getting hot.
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that’s wha
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
