Posted by Steve_Case450 on February 15, 2013 at 12:08:21 from (68.115.201.66):
Hi,
I recently bought an early 70's Case 450 with the 188 diesel. It's mostly in good shape but the charge pump is losing its prime within a day or two when the machine doesn't sit downhill. The previous owner was aware and just normally parked it downhill.
Based on my searching and the older threads I have read here in this forum (and elsewhere), it appears that rebuilding/replacing the charge pump would be the fix.
However, among all the suggestions from people to replace the seal, I haven't seen any information about where to get one or what type it is. Where is everyone getting the rebuild kit/shaft seal from? I'd rather not spend $300 on a new pump if I can just replace the seals. I have yet to pull the pump to look at the shaft seal to avoid potentially making it worse by further damaging the seal so I'm not sure if it is a widely available type or not.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
