Posted by PD Mechanical on January 25, 2013 at 06:53:37 from (74.111.31.59):
In Reply to: JD 350 Steering posted by Earl T on January 19, 2013 at 18:22:58:
While 2x4 is correct in saying "If you see grease, new seals to stop the leak & new clutches are in order" this is not the cause of your problem. Oil & grease will often cause the clutches to slip but will not prevent them from releasing. Sounds like you have broken linkages or some type of failure with the pressure plate or throw out brg. or worse case loose housings. If you have questions or need parts, feel free to contact me. Steve.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
