Posted by Dr. Walt on January 23, 2013 at 03:14:00 from (12.2.223.79):
In Reply to: Re: JD 350 Steering posted by 2x4 on January 20, 2013 at 01:13:43:
If it's as "2x4" suggests and you need to get it out of the field & back to the shop, then here's a trick that will at least get it back in: (1) Put about 1 oz. of Brake Fluid into the gear oil in the final drive to swell the seals, (2) Thicken the gear oil in the final drive with "Motor Honey", (3) Flush out the clutch pack with Tetrachloroethylene - if that's not available you can use either Acetone or Methyl Ethyl Keytone. Do NOT leave the solvent in the clutch pack for more than a minute or two, as it will eat up the seals. Make certain that you flush all of the solvent vapors out of the clutch pack. - This trick DOES work, I've done it to get a machine back into the shop.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
