Posted by d9gdon on January 13, 2013 at 10:11:39 from (76.1.99.192):
Mr. Lee said: (quoted from post at 21:20:54 06/29/11) Anybody got any ideas on a bent pushrod,scored and slightly bent inlet valve on a 3204 eng? The piston and connecting rod appear to have no play, the valves were WAY overdue on adjustment and have ALOT of clearence, Machine is a '89 Cat D4-C---RJ007544
I know this thread is old, but I ran across it while searching for the valve lash on a 3204 Cat that I'm working on now.
I just repaired a 3406 Cat engine that did this same thing. The end diagnosis was that the head had an old crack in it between the valves and it was determined that coolant would leak into the combustion chamber after a workday and after having sat for a couple of days, it rusted the valve stem causing it to hang up temporarily which let the push rod fall out of position on the stroke causing it to bend when the piston came up and knocked the valve back up. At least it usually doesn't bend the valve since it's positioned in the head vertically instead of angled like some engines.
Maybe this will help someone in the future.
This post was edited by d9gdon at 10:13:03 01/13/13.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
