Posted by Dr. Walt on December 05, 2012 at 21:39:28 from (12.2.223.79):
In Reply to: Drott Skidloader posted by tpmx on December 02, 2012 at 11:47:03:
Sounds like one of two possibilities; First, check to make sure that someone hasn't switched the "raise" & "lower" lines at the control valve. Second, check the "over-pressure" relief valve on the "Lift" side of the control valve; if someone has had the valve apart & forgot to put back the check- ball or spring,the Hyd. fluid would by-pass the lift side of the valve.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
