Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Drott Skidloader
Posted by tpmx on December 03, 2012 at 15:40:26 from (50.51.180.233):
In Reply to: Drott Skidloader posted by Dennis K (WA) on December 03, 2012 at 13:39:32:
I have manuals for the machine but not my hydraulic system.
I ran the machine tonight some more and I do have go pressure/force with down and curl both ways on the bucket,
I took the handle off the spool and operated the spool through the full stroke and its no different,appears the handle is allowing full travel
I broke a fitting loose on the valve going to the loader lift cylinder and have fluid oming out when the valve is in the lift position.
Without a gauge its useless because I have no idea of how much volume or pressure is coming thru.
Still suprises me the loader will not even try to lift at all,no movement in the cylinders what so ever.
I do hear oil traveling somewhere within the valve when in the up position.
Though maybe it was going back to the tank but thats not the case.
Sounds like its just circulating thru the valve.
I do notice the hydraulic oil looks to be full of air just not a solid color like oil would be.
The valve is a
HYDRECC
V400p320
H2627
I will get a picture of it tomorrow while its light out still
Thats again for taking the time to help with your responses
Latest Ad: Super WD9. [More Ads]
