Posted by tpmx on December 03, 2012 at 12:33:08 from (198.228.228.174):
In Reply to: Drott Skidloader posted by tpmx on December 02, 2012 at 11:47:03:
[quoKte="Dennis K (WA)"](quoted from post at 12:31:06 12/03/12) tpmx, What I am about to write is somewhat generic because I'm not sure what your valve has but here goes.
The spring and poppet you talk about in the spool may be what is called a regeneration valve and the purpose is to refill the upper end of the lift cylinders when the boom is dropped rapidly. Not sure how it may apply to your problem.
Many hyd valves have what is referred to as port reliefs or circuit reliefs for each operation. It would be common for hoist up to have one to protect the cyls and boom if when up something fell from above or a bank would cave in. If this relief was bad or had a broken spring it would cause your problem and would not effect the down operation.
Another thing, is it possible that the linkage is worn to the point that the lever is hitting the frame work before the spool is stroked enough? I have seen this before
Thanks
I am headed home from work and will see what i can determine
I doubt cylinders if you have down pressure but they could be tested for bypassing.
As I said these are generic comments and may not apply to your specific valve.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
