Posted by Stick welding on December 02, 2012 at 13:55:37 from (96.53.210.246):
In Reply to: Re: Drott Skidloader posted by tpmx on December 02, 2012 at 12:26:27:
When you lift up the front of the machine, does it creep down fairly fast? If it holds, it's not likely the cylinder seals that are the problem. If the seals in one or both cylinders were so bad that it wouldn't even lift the boom, they would also cause the boom to creep pretty fast when there was down pressure on it. Can you switch the hoses from the bucket valve to the loader valve and see if it will lift? That could help you determine if the valve was the problem. Putting a T in the hose and a pressure gauge would also help. Does the engine labor when trying to lift the boom? You could have a restricted hose or internal leaking in the valve body.
Today's Featured Article - Sunday Drives - by Cowboy. Summer was finally upon us here in Northern Maine. We have two types of industry up here, one being "Forestry" (Wood Products) and the other "Farming" (Potatoes). There is no shortage of farm tractors and equipment around here! I have been restoring old Farm Tractors for the past 6 years, and have found it easier and less expensive to hit all the auctions and purchase whole tractors for parts needed. My wife who works at a local school, and only has weekends and summers off, while on t
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
