Crawlers, Dozers, Loaders & Backhoes Discussion Board
Re: Ford 555 Injection pump leak at throttle shaft
Posted by abordone on November 27, 2012 at 18:34:01 from (50.104.230.19):
I know this is an old post, but thought I would add a little.
The little pin that Larry is talking about goes through the governor plate.
It has a spring on the back side.
Hold your right hand index finger on the pin and spring as you unhook main governor spring with needle nose pliers and your left hand.
Then you can carefully remove pin and spring, and hopefully save yourself some grief.
Today's Featured Article - History of the Nuffield Tractor - by Anthony West. The Nuffield tractor story started in early 1945. The British government still reeling from the effects of the war on the economy, approached the Nuffield organization to see if they would design and build an "ALL NEW" British built wheeled tractor, suitable for both British and world farming. ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
