Posted by LJD on November 13, 2012 at 05:48:35 from (75.213.154.164):
In Reply to: First time crawler posted by scottg803 on November 12, 2012 at 12:10:03:
Undercarriage parts are getting scarce for many crawlers. So, if you buy - I suggest you either make sure the undecarriage is in excellent shape, or make sure you can still get replacement parts. Aftermarket companies like Berco have stopped making many part for older crawlers.
I've got several small crawlers at different properties. Deere 1010 and 350, Allis Chalmers HD4 and HD6, Oliver HG, OC3 and OC4, and Case 310G.
Besides parts availability, ask yourself if you want a foot clutch or hand clutch, loader or dozer, and if ease of repair an issue. Some are easy to work on and some very complicated.
Also - having a hydraulic reverser is real nice but - it also means a huge expense if repair is ever needed.
How about the drive? Clutch driven or torque converter? My Allis HD4 is torque converter drive which personally do not like. Parts for AC crawlers are also getting very hard to find.
I think the easiest crawler to work on is Case. 310 or 350. No steering clutches to get bad and most parts out in the open. Good parts availability also. Better then for most older Deere crawlers. May be too small for what you want? A Case dozer (6 way blade) weighs around 8000 lbs. My 1010 crawler-loader weighs 10,000 lbs.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
