Posted by mite-help on November 07, 2012 at 17:06:46 from (70.196.8.222):
I am helping repair a hyd leak on a poclain 160 trac hoe. can't seem to find fittings to make up a hyd. hose in my area, & recall nc wayne posted info about a supplier a while back. best info i can find about it is its called a 'gaz 24 degree french male ferrule', the end that is broken is aprox 1/2'' id thick walled tube, bent 90*,with this ferrule & 2 bolt flange, collar attached to crimp to rubber hose aprox 30 in'long-other end is straight, flange. female. [i know this is all metric, but this gives an idea--not big, but i understand its pretty high pressure--tried a make-shift ferrule,no.has to be that 24 thanks for any help---
Today's Featured Article - My Ford Golden Jubilee - by Troy Estes. This article is about my '53 Ford Jubilee and a story that starts with taking the tractor to my brother's Starter/Alternator Rebuilding shop for a wiring fix. The generator was shot as well as all the wiring. I dropped off the tractor expecting a transformation from a 6 volt to a 12 volt system utilizing the original generator housing, and a total rewiring of the whole tractor. The front end center pin bushing was worn also so I ask that they replace it if they had time. Well, that’s wha
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
