Posted by Dennis K (WA) on November 07, 2012 at 08:55:12 from (24.21.78.195):
In Reply to: Hough transmission posted by Bill in IL on November 05, 2012 at 19:46:32:
Morning Bill,
Sounds like your transmission is good as long as it reacts the same when cold.
The pressures come from a pump mount on or in the converter. It draws oil from the trans sump, sends it to a regulator and back to the transmission selector valve. Oil that the main pressure system does not need goes to the converter.
Problem is, it has been sooooo long ago that I can't remember the layout of the converter assemble for sure on the H60B. Hough used that transmission in a lot of different models but I don't think the converters were all the same on different models. There is going to be a main pressure regulator mounted some where and a converter regulator some where but I can't remember where. Your problem may be related to converter pressure when cold.
Could you post a picture of the back of the converter and a picture of the converter side of the transmission? This may jog my memory.
Otherwise, as another poster stated, mechanical failures of a converter generally don't come and go and problems are usually when hot not cold.
Today's Featured Article - Magic Moments - by Tyler J. Woods. Magic moments don’t just happen. You have to help them along. This morning, I got up early. It is my day off from my regular workweek and I had a lot of things to do. It’s fall, and with winter coming on, there is a lot of work to do before weather closes in.
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
