Posted by Dennis K (WA) on November 06, 2012 at 13:12:55 from (24.21.78.195):
In Reply to: Hough transmission posted by Bill in IL on November 05, 2012 at 19:46:32:
Hi Bill,
Now that we know you have good clutch pressure I'll give you another test.
Apply the brakes using the right pedal or put the machine against a bank so the wheels will not turn. Try each gear, the driveline between the converter and transmission should not turn while doing this no matter what the rpm as long as the wheels do not spin. Driveline should spin free in neutral or when declutching. If everything is tip top you may not be able to hold it in 1st gear. If driveline spins when doing this you may have clutch pack problems but unlikely they would all be bad.
Forward clutch is common to all three forward gears and rev clutch is common to all three reverse gears.
The internal workings of the converter usually work or not work.
Today's Featured Article - Madison's County - by Anthony West. Philip Madison has been a good friend of mine for quite some time. He has patiently suffered my incessant chit chat on the subject of tractors for longer than I care to remember, and on many occasions he has put himself out, dropped what ever it was he was doing, to come and lend a hand cranking handles, or loading a find onto a trailer. Although he himself has never actually owned or restored a tractor, he was always enthusiastic and always around helping with other peoples projects.
... [Read Article]
