Using Your Tractor & Crop Talk
Discussion Board - Field prep
Allen
08-21-2003 19:56:15
I have a couple of small open tillable spaces that I am in the process of preparing for planting. Each is 2-3 acres. I am planning on planting forage for the wildlife such as a clover mix I purchased from the local Farm Bureau, Grass, Peas, Turnips. I am looking to hold the deer, turkeys etc. in my 40. It has been 3 seasons since any farming has been done on this ground. I have plowed some and am in the process of discing the whole lot. I am concerned about the areas with heavy clay. These areas don't seem to be smooth enough to plant. What else can I do to break up these clumps? Am I wasting my time if I plant without doing soil tests?
JS
08-27-2003 19:38:44
 Re: Field prep in reply to Allen, 08-21-2003 19:56:15
soil tests, my state lab charges $12, pretty cheap for all the work that goes into trying to establish a crop.
Sid
08-22-2003 17:58:19
I where doing that I would not worry about soil test.
allen
08-22-2003 10:46:37
Thanks. I have a 3 section tooth type drag that I am planning on trying first. If that doesn't work I have access to a 10' steel beam that I may try to use also.
Dana
08-22-2003 05:49:12
You might try using a drag. You can make one out of most anything such as old railroad ties, telephone poles, logs etc. The heavier the better. They usually do a better job of busting up clods than a disc.
