Using Your Tractor & Crop Talk
Discussion Board - 2002 Ram 3500 Dually Diesel
A Cosh
01-01-2006 16:42:11
Im looking into one to buy. Any good or bad dealings with this truck? Want to pull an IH 706.
Fighting suburbia in NC
01-11-2006 06:01:59
 Re: 2002 Ram 3500 Dually Diesel in reply to A Cosh, 01-01-2006 16:42:11
Check the DTR for used truck FAQs.
If it is a five speed then there is a potential for the 5th gear nut to back off if lugged under load - there is a permanent fix. If it is an auto then check the trans fluid for burnt smell and see how it shifts - if it shudders under full throttle with the torque converter locked in then it will need a new TC eventually. Ask to see if there has been a fueling box added in the past. Biggest thing is the fuel pressure - if it has ever tanked then the VP-44 is gonna be an expensive issue eventually. If it is a 6X6 then check the trackbar for wear as well as make sure the 4WD shifts in and out easily (front axle disconnect, I think).
Good trucks, motor will outlast the body.
fox
01-06-2006 05:37:51
I"d at the least get the fuel pressure checked, and codes read.
If the lift pump is or was bad, the injection pump may need replaced. Look for code 0216. This is a code that tells you the injection pump is on its death bed.
If the power is low or the truck is week in performance, most likely the VP-44 injection pump is finished.
It will cost at least $1000 to $3500 to change it.
Good luck.
Larry NE IL
01-02-2006 20:17:08
I bought a '06 this fall and love it. Cummins and 6 speed auto. I've always owned Dodge trucks and cars so I'm kinda partial, but I really like this one. My biggest problem with buying this year is with the dealers.
Doug in IL
01-02-2006 06:58:07
We have one. It has been a good truck. Ours is a 5 speed with about 100,000 miles on it. Did have a little troble with the lift pump. Was fixed under warranty.
