Disking old field ??
Scott
07-15-2003 18:08:16
I have an old field that I am trying to reclaim.
I have been reading about disking. My question is, are you talking about plowing and then disking or just disking the sod to get the seed in the ground?
Steve
10-18-2003 21:55:18
 Re: disking old field ?? in reply to Scott, 07-15-2003 18:08:16
Hey Scott. If you want to totally reclaim your field (depending on your situation), I would definately suggest plowing 1st and then either disc or rototille, then lightly harrow, seed and pack with a cultipacker or the like. By plowing, you are turning the existing saud under, therefore you are starting with fresh dirt. Good luck and have fun.
paul
08-10-2003 21:24:34
Most seem to just want to disk, but you can't kill sod with a disk. Plow & then disk is the way to do it, but I'll bet you try just the disk anyhow.
--->Paul
screaminghollow
08-09-2003 02:23:18
I have been trying to get a field into grass for grazing and hay. It had been a corn field for 10 years. I mowed the stalks with a brush hog, then lightly disc'ed over part of it. I spread seed by hand over it. Then I disc'ed over the part where it hadn't been done yet. Where I disc'ed before spreading the seed, the grass came up thick and fairly weed free. Where I disc'ed right after spreading the seed, it is full of weeds. There is one spot where I just spread seed and then mowed the weeds and corn stalks. That area took the longest for the grass to take. Where I disc'ed first, there are no thistles. Where I disc'ed or mowed after spreading seed, there are thistles. Just my experience, nothing scientific and for the life of me I can't figure out why the difference.
Scott
07-16-2003 21:30:18
Mainly, the initial disking will help break up the sod that is there. I think I'd run a disk over it first, then plow. Should be easier to plow then.
Doug Rogers
07-16-2003 07:56:27
I'm in the process of doing the same thing. Having disked about 5 times so far this year, I finally broke down and sprayed with 24D to get the weeds taken care of. One guy early on told me to plow everything first which I did not do. If doing it again, I would definately plow first to bury and kill all weeds and their seeds. Then disk to prepare seed bed. If you have access to a springtooth, that will help as well.
joe
07-15-2003 20:21:39
I am hobby farmer, but would always plow the field and then disk it. Let it sit a few days but not long enough to get dusty then disk several passes at different angles.
