Using Your Tractor & Crop Talk
Discussion Board - Perfect equipement line of old for today
720 Pony
11-21-2004 16:19:55
I am 48 years old. From 10 years old to 18 I lived and worked on a Minnesota Dairy farm. We milked about 50. We crop farmed 200 acres. Fed out the stears and about 200 feeder pigs a year.
Farming has changed a lot since then. Our big tractor was a 70 John Deere gas. We cultivated and picked ear corn and filled silos with corn silage. The soybeans where combined by the Neighber with his always new John Deere combines.
I have worked as a carpenter and a contractor the last 30 years. Two cylinder John Deeres are my hobby. I now own a very nice 730D and I bought a 80 acre old style working dairy farm last year.
My Qeustion is what Equipement wood make a good complete line of equipement for serious hobby farmer today. I don't need to make a living with this but I want it to profitable.
Wood you still plow or go with less tillage?
Wood you use chemicals or cultivate?
I was thinking maybe 1/3 hay and 1/3 corn and 1/3 beens. Sell the beans and feed out the corn.
I want to do this but I have not enough experiance with modern practices to make good decisions. Any thoughts anyone.
Thanks
730 Pony
Brian Rett
12-25-2004 11:03:05
 Re: Perfect equipement line of old for today in reply to 720 Pony, 11-21-2004 16:19:55
It all depends on how much of a slope you live on. You also need to worry about runoff.
paul
11-21-2004 19:11:21
Which part of Minnesota? For the no-till question. Does not work at all in my part, but might where you are? The rippers that are used instead of plowing are still pretty expensive, and generally take a lot of hp - not many little versions out there...
If you like green, a 7000 jd planter, a 2700 or 2800 plow, a field cultivator, and a tractor to pull it would be great.
You can have it harvested for $20 an acre, probably a good way to start anyhow... I have found Gleaner combines to be a little easierto work on, if you care to go a different route. JD 6600 are plentiful & not that expensive if you want green.
--->Paul
730 Pony
11-21-2004 20:28:54
 Re: Perfect equipement line of old for today in reply to paul, 11-21-2004 19:11:21
Thanks Paul
Central Minnesota, Litchfield,Wilmer area.
Good soil, 150 bushel corn and 50 bushel beens around 1970's. 38 inch rows. Lots of cultivateing. Three bottem plow,disk,springtooth,
494 planter, 227 mounted picker. The last year I was there we added a 4030 with soundgaurd cab,pull type IH picker,three point plow and a pipeline. After I left they added silo unloaders and a grinder mixer.
Thanks again Paul
730 Pony
JMS/MN
11-22-2004 13:51:27
 Re: Perfect equipement line of old for today in reply to 730 Pony, 11-21-2004 20:28:54
Sounds like the Meeker, Kandiyohi county area, although you must be on the heavier soils to get yields like those. Most of us here use conservation tillage- disk chisels after chopping corn stalks, same machine or basic chisel after soybeans, small grain, etc. Field cultivators rather than disks. No-till is not popular because of the dark, heavy soil, although some use ridge-till if they don't have livestock operations. (Ridge-till works better if you don't cross ridges with spreaders, wagons, etc. between the ends of the fields. Regarding opoerating an active dairy farm- much more regulation now than in previous years, and between that and price fluctuations, most of us figured it just wasn't worth the hassle of Mom and Dad and the kids working seven days a week to feed an ungrateful public and putting up with all the hassle. There is a life after dairy cows! Especially after two years of the farm price being at 75 cents per gallon.
730Pony
11-22-2004 19:34:33
 Re: Perfect equipement line of old for today in reply to JMS/MN, 11-22-2004 13:51:27
JMS/MN,
Thanks for your help. I am not crazy enough to want to milk cows again. Some Stears would be ok.
JMS, I'm the same guy with the pole building so Email me if you have someone for the pole building as yours was still blocked.
730Pony
JMS/MN
11-24-2004 12:04:00
 Re: Perfect equipement line of old for today in reply to 730Pony, 11-22-2004 19:34:33
The cows are gone for just over three years now and we haven't missed them yet. As far as ripcord489@hotmail.com I'm concerned, despite State efforts to revitalize the dairy industry, it will not come back. It's all about the money. People get tired of the roller coaster prices and the 24/7/365 schedule.
