I have a small area among a small woodlot (which I am going to use to grow firewood and lumber for milling) that I want to make a garden in.Right now the garden area is somewhat cleared of the bigger trees and has several small bush trees like dogwood left for me to pull. The ground is full of running vines and pricker type weeds. What is the best way to pull a stump that is about 6-8 inch diameter and sits only 5 inches above ground? Next time should I cut higher off the ground? To "farm" this garden I have a 1944 Farmall A with a McCormick Deering A-91 Plow attached. Yesterday I tooled around a bit with the plow which made various piles of the vines/bark and dirt. What I figured out is that I need a longer cleared distance to operate the plow so I have to do some more clearing of trees and bark. What else should I be doing to get ready for spring planting? I have locust logs ready to be made into fence posts which will form the garden fence. The reason I posted this question is that I read another guys experience plowing his 1 acre field (mine is way less then an acre) and the mistakes he made were helped by asking here. Thanks Al Fitch
