Bean poles
bill b va
04-22-2003 12:33:21
what do commercial growers use for pole beans to climb ? i love kentucky wonder pole beans but the poles are a hassle ...don't last long .looking for a easier way for my age .
BigMac
04-23-2003 10:47:14
 Re: bean poles in reply to bill b va, 04-22-2003 12:33:21
Commercial growers plant bush varieties to avoid the costs of supports for pole beans. Their harvesters pull up bush and all if they are not using hand labor to pick.
We grow our pole varieties on a wire support system or bamboo poles. The wire lasts forever and the bamboo will last a minimum of 10 seasons and is more portable.
BigMac
Mudcat49
04-23-2003 03:57:01
Ky. Wonders are a bush pole type bean, yew don't need poles to grow them.
bill b va
04-23-2003 05:40:41
 Re: Re: bean poles in reply to Mudcat49, 04-23-2003 03:57:01
last year had some over 8 feet tall on my poles . they are a old old variety . used to be grown with field corn . there is a bush variety but not the same bean
Tinker
04-22-2003 19:42:59
Just plant your beans with the corn, and let the beans run up the cornstalks. Hickory King corn with Blue Lake pole beans planted in the rows has worked fine for me. Lets you get two crops at once from the same space. Sweet corn stalks aren't strong enough to hold up beans. The vines will pull the stalks over.
Randy
04-22-2003 13:01:07
My dad just puts up a wire fence and lets them climb all over that.
JohnnyB
04-23-2003 14:35:33
 Re: Re: bean poles in reply to Randy, 04-22-2003 13:01:07
We drive a T post at each end of the row and string hay twine between the two posts. Works good for tomatoes also, you can burn it up with the vegetation after harvest.
jeff in pa
04-29-2003 09:49:17
 Re: Re: Re: bean poles in reply to JohnnyB, 04-23-2003 14:35:33
I saw plans for a trellis made from pvc.
I am testing one that i made from 3/4". make two 5 ft squares then lean and bind them together and run twine up and down.
At the end of the season they can be pulled apart and stored easily.
