1940 Farmall A
Greg Miller
03-11-2003 10:39:36
i just acquired a 1940 Farmall A that has a mounted one row cultivator on it right now. it also has a mounted one bottom plow coming with it (if i can find the other pieces to it). my intent is to bring this tractor home, have the gas tank repaired and put it back into service working gardens. if i can get the plow taken care of and get a disk for it i will be all set. eventually i would also like to find a blade for it so i can move dirt, rock and snow if i want to.
DAVID M
03-15-2003 20:18:40
 Re: 1940 Farmall A in reply to Greg Miller, 03-11-2003 10:39:36
Sounds like a good plan you have there.I have a 1946 A Farmall and i would love to see some pics of your tractor with the cultivators hooked up on it.These tractors make fine pieces of gardening equiment.I use mine constantly for all types of things in and around the garden.I have a disc breaker cultivators(that I cant seem to get hooked up right)a tandem disc harrow that has adjustible angle to it(get piece of equiment) and a 5ft pull type bush hog.Hope you get to using your tractor and enjoying it to the fullest very soon.If I could help out with any info give me a shout and I will do all that I can for you. Thanks
