Ideally, you'd like to have soybean stubble to seed into rather than corn stalks. That being said, doesn't mean you can't. Be careful using a disk in the spring. Ground to wet and you will run into a compaction problem and not have a fine seed bed for the hay. Maybe "hire" a farmer to field culitvate rather than disk it unless the spring in a dry one. I have 10 head here, limited pasture and 15 acres of both grass and grass/alfalfa. For good hay for them, I need all 15 acres (mamma nature doesn't let ya get it up good all the time). Back to prep. Try to get as many stalks worked down as possible. Grass and alfalfa seed like shallow seeding depth for best results. Fertilizer will be needed to get a good start on the seeding. Get soil samples for fert needs. If you are putting in alfalfa, try to talk the dealer into putting the alfalfa seed into the slurry mix, it works great up here (have done it myself, alfalfa still goin well after 5 yrs) seed grass and cover (if you want cover crop, direct no cover seeding is catching on up here) crop before fertilizing, fertilize and just drag or run a packer over the field. If you can time the rains right, preferably do the fert just before the rain to minimize possible fert burn. I know that others will have a few things to say that the above won't work or caution about. But it has worked well for me in the past. When I did the above on 8 acres (direct seed with the fert no cover), I sprayed Buctril (pretty sure, memory is a bit foggy after 5 yrs) when the alf was at the 3rd trifoliate (labeled for alf at that stage) to control broadleaves. In June took off a crop of "foxtail" hay of about 60 - 70 bales an acre (horses loved it). Mid August took off about 50 bales of alfalfa/ac and left the field to set up for wintering. After 3 yrs of straight alf, ran through the field with a parabolic ripper (twice checkerboard pattern), leveled, interseeded a grass blend. This past year(2nd for the grass)I took off about 200/ac (60#) bales off the field. If the weather would have cooperated at the end of June, I could've done a 4th cutting. My straight grass last year only gave me one cutting, no rains from July on. Good luck Bruce
