Using Your Tractor & Crop Talk
Discussion Board - Pasture mix for beef
akb
03-15-2008 22:41:18
What are you guys using for pasture mix
for beef.Grass blend or alfalfa?
Located in central minnesota
730virgil
03-16-2008 20:23:27
 Re: Pasture mix for beef in reply to akb, 03-15-2008 22:41:18
brome,orchardgrass and redclover. only problem i have is spraying for thistles if you have any keep the red clover out. cows love it. i like it not much bloat risk like alfalfa
hayray
03-17-2008 07:42:03
 Re: Pasture mix for beef in reply to 730virgil, 03-16-2008 20:23:27
I was wondering about the bloat risk with the red clover since I plan on putting a bunch in this summer and graze it. I had several people that said it was mostly like alfalfa for bloat. Trefoil I know has no bloat risk but I get alot more yield on fields of red clover then I do on trefoil.
Bill(Wis)
03-18-2008 16:34:58
 Re: Pasture mix for beef in reply to hayray, 03-17-2008 07:42:03
I've seen holsteins bloat on red clover. Trick is to give them a good feed of dry hay before turning them out on pasture and don't turn them out too early when there's still dew on the clover. That might be pretty late by the clock because of daylight saving time.
730virgil
03-18-2008 18:39:07
 Re: Pasture mix for beef in reply to Bill(Wis), 03-18-2008 16:34:58
how much red clover do you have in pasture? i haven't had any problems (knock on wood). because of thistles i have wondered if should hit pasture with 2,4d and frost seed red clover next year.
hayray
03-16-2008 09:57:49
I have a lot of orchardgrass and brome in my pastures with some alfalfa and clover. I am going to plant a pasture of red clover and annual ryegrass this summer and then switch to orchardgrass in the fall and turnips in the late fall and early winter.
sd pete
03-16-2008 09:56:22
Good old native grass.
