Using Your Tractor & Crop Talk
Discussion Board - Leafhopper resistant Alfalfa
AB
12-21-2007 13:42:00
Planting a new patch of #1 quality Alfalfa in a previously corn,wheat,soybean rotation field. Hay will be sold. Leafhoppers are a common problem here in SW Indiana. Our one and only local crop service charges extra to clean out their rigs to spray insecticide only.
Leafhopper resistant variety is about $15 more per bag than non-resistant. Anyone have experience with Leafhopper resistant varieties? Local neighboring Dairyfarmer has used a 60/40 mix with some success.
52BMAN
01-03-2008 07:43:31
 Re: Leafhopper resistant Alfalfa in reply to AB, 12-21-2007 13:42:00
I conduct the Iowa Forage Variety Tests. Check out the leafhopper resistant trials in the link below. You usually see up to 1 ton/a. advantange over susceptable checks. The new resistant varieties, are definatly worth planting in your area.
IaGary
12-21-2007 15:32:37
I have used it and can tell a yeild advantage where the risitant alfalfa was planted.
But it is resisant not a cure all to feafhoppers.
Is it worth the 15 dollars.
I would use it again.
Gary
AB
12-23-2007 16:07:47
 Re: Leafhopper resistant Alfalfa in reply to IaGary, 12-21-2007 15:32:37
I think that's the route I'll take. Thanks Gary
