Using Your Tractor & Crop Talk
Discussion Board - john deere 730 d
A puller
10-19-2007 17:50:01
What size disk, field cultivator will a john deere 730 d pull?
James22
10-21-2007 09:42:18
 Re: john deere 730 d in reply to A puller, 10-19-2007 17:50:01
I have used four 14's (JD 145A) and 14 ft JD BWA disk with good results. I also have a 5-14 JD 66H but I think it would be a little much in heavier ground bottom. I had an 18 1/2 ft IH 45 field and wouldn't consider putting it on the 730. This was used on the JD 830. A 14 ft field cultivator would be a good match. Buy an 18 1/2 and don't use or just remove the wings.
Joe in Ne
10-20-2007 08:48:33
We used to pull a 14ft ih 37 disc 4-14 bottom plow and 181/2 ft field cult. Did fine on all of them.
sd pete
10-19-2007 22:45:20
oops 12 foot
