I'm in the same boat right now. If you get a sicle mower stay away from the 7' ones and go with the 9'. I have an old JD 224 small square and it does a good job. My ole NH 55 side deliver rake has about had it. Just 1 tractor, it will be tiresome to switch impliments.at least i have a super a to rake with.just have to switch the mower and baler on the other one. The disc mower will allow you to start cutting sooner if there is some moisture still on the grass.And you won't need several sickles.Just touch the knives up with angle grinder. sickle mowers do not like any moisture, will ball up worse.and need 2-3 extra sickles to rotate out for sharpening. My .02 is check everthing out real good. look for welds,repair,bent metal,missing teeth,tines. On sickle mowers check the rock guards and holddowns for wear.Also the bottom edge of the bar for wear. if you run your hand on the bottom of the bar and it feels like a washboard it has seen quite a bit of use. usually it will wear between the bolts on the back edge. Not sure about other balers but mine you can trip the measureing arm and rotate the wheel and check the tying timeing.personally i prefer wire over twine. mice do not eat the wire off. My equipment is JD 224 baler ,Nh 55 rake. NH 451 sickle mower.Still need small round baler. I have 80-100 acres to bale. And i do not want to square bale it all.I was getting it baled on the 1/2's but never when it needed cut,always to late to get 2 cuttings.
