Fordson dexta oil levels
mick
01-29-2000 05:59:48
I need info on Fordson dexta gearbox oil capacity and diff oil capacity , is their a plug to unscrew on the side that determines the correct level?
Also the hydraulics do they run of the gearbox oil? or is there a seperate resevoir.
thanks
Burrrhead
01-29-2000 12:06:01
 Re: fordson dexta oil levels in reply to mick, 01-29-2000 05:59:48
The transmission level check plug is about center of the tranny on the right side. If it's still original its a square headed pipe plug. The only one in the right side.
The differential and hyd plug is on the left side of diff beside the pto shift handle mount stud. The best way to get it in and out is to push the clutch pedal down with left knee while working with plug. The plug is agravating to get out or in with the clutch pedal in the released position.
