Tractor Talk Discussion Forum
PTO parallel gear box...
Tor
05-18-2008 05:03:37
Hi.
Where can I find a small PTO ca 1:1.5 gear box with male input shaft and female output( both shafts parallel with 1 3/8" 6-spline).
I have a pto AC generator which I want to run at a lower motor rpm than 2100 to save fuel....
Thanks for tips on sources for new and used such gear boxes. Max drive needed 30hp.
regards
Tor
Steven f/AZ
05-18-2008 12:38:59
 Re: PTO parallel gear box... in reply to Tor, 05-18-2008 05:03:37
Another thought is a step-up gearbox from another generator... if you can find the proper step.
buickanddeere
05-18-2008 10:32:31
1134 engine rpm if running a 1000rpm pto with 540 stub shaft. And engine capable of 30HP/20KW generator output would have to be rated at 56+HP turning 2100rpm. If loaded at low rpms engine cooling could be a factor. How much fuel are you counting on saving?
Tor
05-18-2008 12:30:17
 Re: PTO parallel gear box... in reply to buickanddeere, 05-18-2008 10:32:31
A bit more info:
I use my 58hp JD 1630 with 540 rpm pto. The generator is capable of delivering 15kVA, but I won't draw more than max 5kVA for pumping and or welding at remote places. This tractor will have no problem keeping the rpm stable at this power.
Just as much as saving some fuel the reduced noise and less environmental impact were reasons behind this post...
Computers will have no problems running off 50 or 70Hz as I mentioned the AC get rectified in the PS' front end circuit. They will though strongly dislike staying connected when powering up/down huge inductive loads because of voltage spikes. However those spikes are not caused by varying rpm and this problem will be the same from a constant rpm setup.
Thanks
Tor
onefarmer
05-18-2008 09:55:46
It would take a bit of imagination to build. But what about using an old truck tranny mounted backward. Drive the tail shaft with the tractor and the input shaft speed increases according to the gear you put it in.
Steven f/AZ
05-18-2008 09:52:05
Forgot in my last post...
What tractor are you using? What horsepower? What are you going to run with the generator?
With this info, people can give a little better answer.
Steven f/AZ
05-18-2008 09:50:53
We've hooked up our 540 PTO generator to the 2590 Case 1000 PTO shaft and let the tractor loaf along for hours at a time without any trouble.
Run everything except the computers that way with no problems.
ALSO, sometimes we just need to use some basic power tools at a remote location with the big generator - then we run the 1086 on the 1000 shaft loafing along.
massey333
05-18-2008 08:30:54
It is your call.but doing that can be a very-very expensive learning experience if you have any Solid State or Electronic equipment because you will not be able to maintain a solid 60Cycle current.Most if not all tractors won't maintain a even enought RPM at half-two thirds speed.Your call Just a Warning ahead of time.Your 2100 will turn into appox.1400 RPM.
Tor
05-18-2008 09:40:19
 Re: PTO parallel gear box... in reply to massey333, 05-18-2008 08:30:54
As of stable RPM at half - two-third of full RPM with tractors I must say that I have the opposite experience. My JD1630 (58hp) is very stable under various loads. My former MF also was very stable.
Also varying RPM in generators will seldom have any impact in modern electronics as the AC current is rectified in the SM power supply's front end. Wrong rpms will have more impact on electrical motors and old transformer welders etc..
Tor
olddog
05-18-2008 10:29:12
 Re: PTO parallel gear box... in reply to Tor, 05-18-2008 09:40:19
Many electric motors , vacuum pumps, compressors, a bank of fans, milk pumps etc come on automatically at most farms. If you're running near maximum capacity at 2/3 or 1/2 speed of rated HP speed, don't matter if you have 30 or 130 rated HP the governors and pickup on the tractor is slower than electricity. A 100 HP rated @ PTO speed tractor does NOT always make 50 HP @ 1/2 speed.
IF you are running a constant load, especially if you are in attendance, you could save the fuel. Which is quicker, getting back to full load RPM in lo gear or road gear? Same thing applies.
olddog
05-18-2008 09:28:39
I second this mans comment. I've been out in all kinds of weather and all times of the day to fix equipment on the farm that was ruined because of this. ELECTRICITY IS WAY FASTER THAN THE GOVERNORS ON YOUR TRACTOR.
At least when your tractor is up to PTO rpm, when you flip the silo unloader (or any other hi load) on, it can recover quickly enough to maintain voltage AND 60 CYCLES, to protect other AC sensitive equipment. If you are just running lightbulbs or heaters, go for it! Otherwise, buy good insurance.
Bob
05-18-2008 08:24:51
Hub City Gear makes PTO speed-change gearboxes, but they aren't CHEAP!
Third Party Image
Bob
05-18-2008 08:33:56
 Re: PTO parallel gear box... in reply to Bob, 05-18-2008 08:24:51
P.S....
Take a look at SurplusCenter.com.
They have a variety of gearboxes, NOT many with PTO splines, though.
jimNCal
05-18-2008 08:11:18
Your local bearing/motion shop will have a pile of catalogs for the rep to look thru. An internet search pulls up too many hits to look thru in an evening.
Tor
05-18-2008 12:36:40
 Re: PTO parallel gear box... in reply to jimNCal, 05-18-2008 08:11:18
Which google searchwords did you use?
I am a frequent google user but did not find many hits for suppliers of parallel (inline) tractor pto gear boxes with female/male 6-spline shafts....
There were millions of splined shaft gearbox hits but very rarely the kind I am looking for. That's why I posted it here where I hoped to find people already using such devices...
Thanks anyway ;-)
regards
Tor
coloken
05-18-2008 06:32:10
Can't help you, but sounds like a good idea. Like pulling a hay rake No need to have the engine wide open RPM. Not talking about lugging an engine her, just letting it take it a bit easier.
