Tractor Talk Discussion Forum
liners.
kenfarmall
05-03-2008 16:24:05
Hi Guys.
I took a set of liners out of a Farmall H. I have a set of almost new liners that I want to put in, how do you guys put them in ? thanks for any help you can give me. Ken.
coloken
05-03-2008 19:05:12
 Re: liners. in reply to kenfarmall, 05-03-2008 16:24:05
Squrting a little propane through them will cool them down too.
glennster
05-03-2008 16:30:21
clean the outside of the liners so there is no rust on them and they are smooth, then i put the liners in the freezer overnight. clean up the cylinder bores in the block so they are smooth and rust free. just before putting the liners in , i wipe the bores down with kerosene to lube them, then use a stout wood block and a mallet and drive the liners in. they should go in easy when they come out of the freezer, it shrnks them just enough.
Spook
05-03-2008 16:46:44
 Re: liners. in reply to glennster, 05-03-2008 16:30:21
I did pretty much the same, froze the liners, put a electric heater under the block. The liers dropped right in.
