Tractor Talk Discussion Forum
ford4000diesel selecto shift
Kevin Davis
04-16-2008 17:58:40
I have an old tractor with many maintance issues and need words of wisdom. main issue is the pto no longer shuts off it is always ingaged. unsure of how big the repair is and how many part to correct. need to know if the conversion kit 12 volt will also work on my tractor with some minor mods. Please help
balatonm
04-17-2008 08:53:02
 Re: ford4000diesel selecto shift in reply to Kevin Davis, 04-16-2008 17:58:40
You should be able to stop the pto with your boot or by puting a load on when its diengaged. Other wise, the pto spining when not engaged and with out load is common on tractors with SOS.
IH2444
04-17-2008 06:14:07
I thought 4000's were 12V ?
soundguy
04-17-2008 06:04:42
Is the pto just freewheeling.. or is it actually powered all the time?
soundguy
Joe(TX)
04-17-2008 05:02:27
It's Select O Speed
dieselpaul
04-16-2008 21:35:23
hello kevin---your pto is a clutch-pack lockup-,cable controlled. I think these sos trans had this problem, due to plates in pack warping, binding up, locking it in. it would need to be torn down to correct if this is problem--But ,find a manual, check cable adjustment first---your 4000 can be converted to 12v, no problem. paul
john in la
04-16-2008 18:19:35
What year 4000 are we talking about.
If you do not know can you at least tell us is it a 4 cylinder or a 3 cyl engine.
Your best bet is to come over to the Ford board on this site as there are many guys over there that can help you out.
