Tractor Talk Discussion Forum
JD 3010 Carb adjustment
TPIA
04-09-2008 15:52:50
I replaced the alum carb on my 3010 with a new cast iron one . How do I adjust[ set ]the needle valve etc ? It tries to start now but won't keep running thanks for any info. TOM
msb
04-09-2008 19:12:24
 Re: JD 3010 Carb adjustment in reply to TPIA, 04-09-2008 15:52:50
Adjust the screw on top at slow idle where the engine runs the best. Set the bottom screw at 1 1/2-2 turns open. Then with the engine warmed up real good and the throttle set wide open,very slowly turn the screw in until the engine starts to lose RPMs. Then slowly open the screw until the engine runs rich. Usually about 1 1/2 open . Then split the difference.----Then repeat the process to fine tune it.Slow idle speed should be set at 600 RPM.
TPIA
04-10-2008 05:50:21
 Re: JD 3010 Carb adjustment in reply to msb, 04-09-2008 19:12:24
msb A big thankyou for the info Tom
