Tractor Talk Discussion Forum
MF165 PTO pump problems
dennis4120
03-20-2008 04:56:17
Bought a MF165 with a PTO pump to run the loader and I added a 6" brush hog. The problem is that the 10"" shaft that runs thru the pump shears in the coupler. The brush hog has a 1/2"" grade 5 shear bolt that should fail. The shaft is dead soft. Do I need a harden shaft and coupler?
If so were can I buy them. Been unable to find such a thing.
Thanks
MSM
03-20-2008 06:22:07
 Re: MF165 PTO pump problems in reply to dennis4120, 03-20-2008 04:56:17
Did you shorten the mower pto shaft to compensate for the added length of the pto pump. You may be binding the shaft because it is too long. Also don't try to lift the mower to full height,the added pump length will cause joint bind even if you shorten the shaft.
dennis4120
03-20-2008 08:28:47
 Re: MF165 PTO pump problems in reply to MSM, 03-20-2008 06:22:07
The mower PTO fit without shortening but is all the way in. Would cutting it down help.
Dennis
Allan In NE
03-20-2008 05:33:00
Hmmmm,
Sounds like a cheap China-type knock off?
Just can't imagine twisting off the real McCoy. 'Bout $35 at any tractor parts house.
Allan
third party image
J Schwiebert
03-20-2008 05:32:56
Have you though of a front mounted pump?
soundguy
03-20-2008 05:32:09
Most shear bolts i see are soft grade 2. Double-Check your mowers manual to see if it needs a hard bolt or not.
Also.. are you saying the pto stub/spline extender is made of mild steel and not hard steel?
soundguy
