Tractor Talk Discussion Forum
FM Magneto impulse setup
loveshisallis
02-10-2008 06:38:34
I have a FM J magneto and have a setup question on the internal timing of it. After the impulse SNAPS on number one compression, WHERE exacty does that rotor point? Does it land directly on number one spot, or where? Or where doe sit stop?
I had no luck in timing it by the internal marks, so I lined it up on the engine fire mark.
Thanks
Keith-OR
02-10-2008 11:42:07
 Re: FM Magneto impulse setup in reply to loveshisallis, 02-10-2008 06:38:34
Here is a great website on the FMJ mags.. He has some really great info and pictures to help on seting up and timing the FMJ mags.HTH
Keith & Shawn(Special Olympic Champion)
Keith-OR
02-10-2008 11:43:31
 PS in reply to Keith-OR, 02-10-2008 11:42:07
Go to page 4..on his website
Keith
Bob
02-10-2008 11:27:17
Before it snaps, the rotor will have stopped just BEFORE the terminal that will be fired.
AFTER it snaps, the rotor will be WELL past the terminal that was fired.
dieselpaul
02-10-2008 07:58:23
when impulse snaps, rotor just fired that cyl.-it will be past cap post. when you don't have marks, try snapping thru, then back up til you feel magnet grab-being careful not to set impulse again--good luck
gene bender
02-10-2008 07:19:31
The rotor will line up on the tower before the piston gets to the top and it will then snap when piston is on TDC as the springs have to get tension before it snaps.
