Tractor Talk Discussion Forum
tractor tire chains
outlaw biker
01-24-2008 14:44:13
if laid on floor how long 16.9 -30 tire chians be?
Aaron Ford
01-24-2008 21:32:50
 Re: tractor tire chains in reply to outlaw biker, 01-24-2008 14:44:13
I believe the chains for my 14.9-28 are near 11 foot in length... Can't really remember. Aaron
CCer
01-24-2008 17:55:57
Pie r round, Cornbread r square.
buickanddeere
01-24-2008 16:10:17
Make certain the chains are tight enough and the cross chains long enough. Needless to say I found out after putting the chains on the tractor I purchased from my Uncle then driving down the road.
ScottyHOMEy
01-24-2008 14:59:26
If you can hang on a sec, I'll go take one of mine off and measure it.
But seriously folks, Michelin lists a rolling circumference of 179.4" s you might call it 15'. But that would be wrong because your chains bind down inside that circumference. If you assume that the circle of the chains would be three inches outside the bead and approximate a 36" diameter, multiply by pi, gives you 113". Allow a little extra for overlap, and ten feet or a little more would be about right. This would need the cross chains to be about two feet long.
kipn
01-24-2008 14:51:51
Its been a long time since high skool.... lol isn't like pie r squared?
pie= 3.14 r squared= radius times radius.
As I said, it's been awhile.
JMS/.MN
01-24-2008 17:18:11
 Re: tractor tire chains in reply to kipn, 01-24-2008 14:51:51
pi r squared gives you area of a circle. pi diameter gives circumference.
