Tractor Talk Discussion Forum
Belarus Batteries
JS13
10-20-2007 16:50:40
I recently just purchased a Belarus model 250 AS.2 cyl diesel,my question is why does it have 2-6volt batteries,would one 12 volt not do the job on this tractor ?
RodInNS
10-21-2007 20:44:20
 Re: Belarus Batteries in reply to JS13, 10-20-2007 16:50:40
By all means go with one BIG 12 v battery, and get big cables.
We never bothered keeping batteries in our 520A years ago because we didn't see the point. There was alwyas a Ford and a chain availale to start the red pig anyway.
The guys I know that still run those tractors have moved the battery box up beside the starter and stick an 8D in there. That cured the starting problems that the 520's had at least... I'm still a firm beliver that the best cure for old red is a stick of TNT though.
Rod
john in la
10-20-2007 20:13:42
I had a older model belarus 250 years ago. When the batteries went bad I replaced the 2-6v batteries with 1-12v battery. I had problems getting it to crank after that.
Since I had already bought the 12v battery and did not want to waste the money I resorted to pulling the compression release lever and let the motor start spinning; then pushing the lever in for the motor to crank.
That was back when I was young and dumb; but hey it worked.
RickB
10-21-2007 04:19:54
 250 years ogo?????????? in reply to john in la, 10-20-2007 20:13:42
"I had a older model belarus 250 years ago." Didn't think you had been around that long, John.
Trkr
10-21-2007 10:08:07
 Re: 250 years ogo?????????? in reply to RickB, 10-21-2007 04:19:54
Dont know if it's long but they have been in the US since the 80's.
Mathias NY
10-20-2007 19:41:41
2-6V batteries have a lot more cranking power than most 12V batteries. Basically from a lot more plate area in the batteries themselves. A lot of early 12V tractors used that same idea. A single 12V would do the same job, but if the tractor is stubborn to start the extra cranking power will be helpful.
T.J.-N.J.
10-20-2007 17:29:07
I have an AS250 also, Mack used to use 6 volt batteries in pairs wired in series because the cells are larger and discharge slower than 1 standard 12 volt would. I think you will like your 250 they are kinda funky but built like a tank and really good on fuel. Good luck T.J.
JS13
10-21-2007 03:55:30
 Re: Belarus Batteries in reply to T.J.-N.J., 10-20-2007 17:29:07
I really appreciate the quick response from every one, I bought this tractor just a short time ago for a winter project and not knowing any thing about this tractor I might need some help, I,m going to include an e-mail address hoping I can hear from you guys , that is if you don,t mind me picking your brain on some subjects about this tractor. ( johesmi@netscape.net again thanks to every one
