Tractor Talk Discussion Forum
O.T. olds.
Roy in georgia
09-04-2007 15:14:02
I am sure someone knows, MY 86 olds locks the left rear wheel from time to time and I do not know why. A friend of mine says his chevy. celebrity does the same thing and so did his wife's so this could be a common problem. Thanks in advanced, Roy
old art
09-05-2007 20:47:54
 Re: O.T. olds. in reply to Roy in georgia, 09-04-2007 15:14:02
check the emergency brake cable that it is not holding on a little bit .BTDT . take the drun off and the shoes shuld be tight to the onchor pin on top. make sure the cable move's very easyto come back.
bradk
09-04-2007 19:37:14
I'm gonna assume that the car in question is a Ciera since the car is being compared to a Celebrity as they are both A bodies.
Notorious problem with these.Everything has to be perfect for the rears to work properly on these cars due to being too light in the rear.
Brake linings must be absolutely dry of brake fluid,no excessive brake dust buildup,and shoes must be adjusted to have slight drag.
Check to see if brake fluid is present.Even shoes that are damp with fluid from a leaking wheel cylinder will lock up. ~brad
Roy in georgia
09-05-2007 21:21:27
 Re: O.T. olds. in reply to bradk, 09-04-2007 19:37:14
bradk This is the kind of stuff I was looking for and by you knowing it was an A body by the celebrity comparison makes me think you are closest to the problem and probably with experience in the matter. front brakes just hit wear indicators and I need to check the rear to see if they need repair just trying to gather ideas before I start maybe next week. This car has only 66000 miles on it and gets around 28mpg I paid $800 for it and because it sat in sister-in-laws back yard for 2 years without antifreeze it broke a head bolt head job and its fine been driving it for 4000 miles so far she gave me $200 back to pay for the repairs thankful for that! I think it will last for some time did the work myself and asked the machine shop guy to verify the mileage on head he said "not many" paid me $47 after I paid for shave and parts out of the $200. Again thanks to all who replied and I will repost results next week or so. Roy
Patrick Martin
09-05-2007 21:24:33
 Re: O.T. olds. in reply to Roy in georgia, 09-05-2007 21:21:27
Brake issues.
Patrick Martin
09-05-2007 21:27:13
 Re: O.T. olds. in reply to Patrick Martin, 09-05-2007 21:24:33
OR warped rotor
Roy in georgia
09-04-2007 19:28:42
these are all things I have thought of just thought maybe there was a common problem here I plan on doing a complete brake job (front and rear) in the next couple of weeks. Most of the time they work fine just on occasion the left rear will lock up when applying gentle pressure on the petal thanks to all who offered their advise in this matter I,ll let you all know what I find. respectfully, Roy
John M
09-04-2007 18:35:07
The rubber brake line is bad, wifes old Celebrity did it and it was the line.
iowa_tire_guy
09-04-2007 16:56:07
I assume you mean it does this when you are stepping on the brake and not just driving down the street. I also assume you have brake drums on the rear and not disk brakes. Then yes check the brake components and clean the dust out. If the shoe seems sticky then pull back the rubber boot over the wheel cylinder to see if fluid runs out. Check both sides of the cylinder. Do this anyhow even if it seems all dry. If everything appears in order and the cylinder is not leaking then it would be the brake drum is egg shaped. Need to replace or have turned on a brake lathe.
Old Ford Mechanic
09-04-2007 16:54:54
Grease or brake fluid.One or both is leaking.
Janicholson
09-04-2007 16:27:42
Pull it apart, it is in need of those components that are:
Leaky cylinders
Bent struts
Weak springs
Thin linings
Excess brake dust (don't breath it)
Cracked drum
Over adjusting adjuster
leaky axle seal
And other opportunities for a complex system to fail.
I am not tearing into you, it is just complex (and broken) don't drive it. JimN
garyh
09-04-2007 16:24:12
Cheeck the brake on the opposite side , it may be frozen orotherwize inoperative, and causing your brakkes to operate unevenly. hph,gh
RobMD
09-04-2007 15:49:07
Sticky, shot brake cylinder.
landlord7012
09-04-2007 15:37:46
sounds like a chunk of brake lining floating around in the drum
ll
