Tractor Talk Discussion Forum
Way OT: Johnson outboards
biggerred
06-30-2007 20:24:53
Yea I know this is a tractor board but,,,I know someone out there fishes from time to time so here is my question. How can I tell the year on my 115 Johnson v4 outboard? I need a starter, but they got to know the year, and I haven't a clue. Thanks
Larry from md
07-01-2007 10:05:16
 Re: Way OT: Johnson outboards in reply to biggerred, 06-30-2007 20:24:53
The serial number is stamped in one of the freeze plugs on the top of the engine block. A dealer can look up the year from there or you can go to marineengine.com and find the year.
Vern-MI
07-01-2007 04:43:01
Try this site....
F.E.Bear
07-01-2007 03:58:41
Look at the seial number and it will have some letters in it. OMC uses INTRODUCES as their numbering system. Convert thr letters to numbers using I as 1 and O as 5 etc. and you should be able to come up with the year unless it is too old. I believe ythey started this system in the 60's.
dan67
07-01-2007 20:54:27
 Re: Way OT: Johnson outboards in reply to F.E.Bear, 07-01-2007 03:58:41
Correct with the word introduces it started in 1980 prior to that they used the year in the place where the letter are and Evinr. used a set of numbers. have a great day
F.E.Bear
07-01-2007 03:57:42
Look at the seial number and it will have some letters in it. OMC uses INTRODUCES as their numbering system. Convert the letters to numbers using I as 1 and O as 5, etc. and you should be able to come up with the year unless it is too old. I believe they started this system in the 60's, maybe before.
Rod in Smiths Falls, ON
07-01-2007 03:39:30
This may have changed but during the seventies and eighties OMC and Mercury used subtle colour differences to determine the years of the motors. For example a tan trim stripe distinguishes the '85 Mercury from the '83. If you spend some time on eBay looking at comparable motors for sale you can usually nail the year of a motor from its appearance.
Jeff in TX
06-30-2007 21:39:49
Look at the title. That is the easiest way.
marlowe
07-01-2007 04:54:17
 Re: Way OT: Johnson outboards in reply to Jeff in TX, 06-30-2007 21:39:49
you have a title for a outboard ????you have to be kidding
smurph72
07-01-2007 06:35:42
 Re: Way OT: Johnson outboards in reply to marlowe, 07-01-2007 04:54:17
boat and motor and trailer each have one in Texas.
dcm
