Tractor Talk Discussion Forum
decisions, decisions---problem Ford NAA
Tim, Ohio
05-21-2007 08:31:56
Hello Everyone,
Starting to have thoughts of selling my Ford
NAA. I've been putting money into for years, a little
here and a little there. Now, the hydraulics
are broken and I started doing the repairs. They
should be fine after a little work on the lift
cover. Then, when running it to test some other
problems the engine started clacking. I guess the
rod bearings are worn. I figure just putting new bearings in won't solve the whole problem. An engine rebuild will most likely be in the 2000.00
range since I won't be able to do it. The carb needs a rebuild and I intend on doing that. I am just waiting on what is next. Just wonder if you would consider giving up on one like this and move
onto a new tractor. I've really enjoyed this old
Ford. It came with the realestate when I moved to the country. I plowed snow with it, moved a lot
of dirt, brush hogged and various tasks. But, boy
it sure has needed a lot of attention in 6 years and is now in pieces waiting for parts. The engine issue really gets me and almost makes me want to move on. In six years I have put about 1,800 into keeping it goig. What do you all think?
Tim, Ohio
Dan hill
05-29-2007 03:27:02
 Re: decisions, decisions---problem Ford NAA in reply to Tim, Ohio, 05-21-2007 08:31:56
Tractors need repairs.My 600 has been in use for 15 years with few repairs.I put a new pto shaft in it because the shaft was 1 and 1/8 and chewed up.Spent 35.00 on the steering.I have a new temp gauge to install.I keep the oil and filter changed.I dont fuss when it needs a part.The 600 does every job I need it for.I have a JD H that Ive spent far more on for new tires than I paid for the tractor.When you are mowing and the calcium starts spraying you need a new tire.I have used a late model tractor to load manure and till the garden, nice rig but it cost 22 grand.Ive kept cattle around for 42 years, they have cost me more than Ive ever gotten out of them.But thats what I like so I keep on doing it.
jubilee johnny
05-22-2007 05:49:42
I have ford NAA (Jubilee) #NAA02124, a very early tractor built in 1952. Your tractor is probably worth getting in good shape. It is a 50 year old tractor so maybe due an overhaul. But, the prospects of replacement could cost you as much or more when it's all said and done and at least you know this tractor and what's wrong with it. I really like mine and may next winter sandblast and paint it. Good luck.
dds-inc
05-21-2007 19:29:25
Guy...1,800 in 6 years = you're tight.
I put 100 bucks a month into a neighbors small utility tractor to properly maintain it. Buying something else which is newer and larger means that you will be dumping MORE money into it sooner or later! Big tractors have big parts and newer tractors have expensive, complicated parts.
Definitely fix up the NAA front to rear and you will have a good tractor. I'm sorry, but saving money = more money in the long run.
Davis In SC
05-21-2007 18:16:43
If you get rid of that tractor, and buy another, you might be "Junping out of the frying pan and into the fire" Once you properly fix something on your tractor, that should be one less thing to worry about.. That is one of my gripes about people that stop by wanting to buy my stuff.. Several have told me that I should sell them mine, and go buy myself another one.. Why in the heck should I do that ?
Glenn FitzGerald
05-21-2007 17:16:39
I'm gonna show my ignorance here, but is the NAA considered a good, durable tractor? Is it a proper match for the job you're doing? If so, I too would fix it up. As others said, they will all require maintenence. The newer, more sophisticated ones hold no appeal too me.
I bought two used older tractors in the last three years. Both were represented as better than they were. When I got them home, the repairs/expences began.
To quote an old bit of wisdom, "A bird in the hand is worth two in the bush" doesn't really apply here, but would help me in making my decision.
I'd fix the NAA.
Glenn
WaltMo
05-21-2007 15:26:17
What can you do to those engines that cost $2,000?
Just thought they could be rebuilt for a lot less. LOL
WaltMo
hay
05-21-2007 12:08:27
well, you could get a new tractor (any color) and in a few years or less be faced with computer electronics problems that would require special test equipment and special knowledge or pay the dealer $75-90/hour labor to diagnose and repair plus parts cost. the old tractors DO require a lot maintence, but, they have NO COMPUTER problems either. your call.
RAB
05-21-2007 11:52:02
Like the others say "better the devil you know than the devil you don"t".
It may not need that much spending on it. It is not worth so much if the engine is knocking. No point guessing if it is rod bearings (unless you know it has little oil pressure or the oil was low). A second hand replacement engine might be a cheap alternative and they are small enough to be fairly easily changed.
Finally you said you have enjoyed it. why change?
Regards, RAB
Don Benson
05-21-2007 10:37:17
Depends on how critical it is to have that tractor running at a particular time. If it is critical to you lively hood get a new one!! if it is for chores around the farm you may want to keep it. My friend has a 2 year old john deer and his payments are 500 a month, he went to trade it in on a new tractor and his 22,000 tractor is only worth 17,000. You may have to put money in the old NAA but it isnt depreciating and collecting interest, my 2 cents
cj3b_jeep
05-21-2007 09:23:05
I guess I'd fix it, at least you are then dealing with a "known" instead of an unknown. As far as new goes, they are nice, but $20,000 is about what you'd spend to get a decent new one of any size to do some of the work you're doing now. Of course, things have really improved in the last 40 + years of tractor development. I drove my buddy's new Kubota recently and it was like a cadillac compared to my old David Brown. Again, I think I'd splurge and have it fixed, and have a new clutch put in while you're there and you should be good to go for years.
glennster
05-21-2007 08:46:43
you could cut and run and buy another tractor. problem there if you buy a used one, you dont know what it will need. then there is the learning curve to figgure out the new tractor and maintanance. if you buy new, its a lot of cash, but little maintenance for quite while. you already are familiar with yours, and you know what has already been repaired-replaced. not an easy decision.
RustyFarmall
05-21-2007 08:42:01
$1,800 in 6 years is only $300 per year. $300 will not make the monthly payment on a new one.
You say the tractor came with the property, so basically the tractor was free. Another $2,000 on top of the $1,800 you have spent so far is still only $3,800, which is just about what you would pay for another Naa, and it would probably need some more dollars thrown at it before it would be trouble free. All of these tractors need money spent on them from time to time. I'd say you are faring pretty good so far.
