Tractor Talk Discussion Forum
oil capacity for 860 ford tractor
alan bane
04-16-2007 18:13:15
What is the oil capacity with a new filter for an 860 Ford tractor. I have an 800 Ford manual and it calls for 5 quarts but it takes 6 and 0ne half quarts to fill . Is there a difference between the 800 series ford tractors.
old
04-16-2007 19:11:42
 Re: oil capacity for 860 ford tractor in reply to alan bane, 04-16-2007 18:13:15
From what I understand its 5 QTs with out the filter and 6 with the filter. But the manual for it says 5 qts, with the filter. So Maybe you have the wrong dip stick which I have seen more then once and if so that can be a problem. BTDT and had that problem with my 841 at one time where some one had installed the wrong dip stick and it did cause a big problem as in a total engine rebuild
alan bane
04-17-2007 02:39:42
 Re: oil capacity for 860 ford tractor in reply to old, 04-16-2007 19:11:42
would an 8N ford have the same dipstick as an 800 series tractor?
old
04-17-2007 11:08:07
 Re: oil capacity for 860 ford tractor in reply to alan bane, 04-17-2007 02:39:42
I don't think so but can not be 100% sure with out takeing a look at the 2 which I could do since I have both an 8N and an 841. Just say the word and I'll compare the 2 to see if they are the same
alan bane
04-17-2007 18:18:48
 Re: oil capacity for 860 ford tractor in reply to old, 04-17-2007 11:08:07
Old, if you don't mind , compare the two and see if they're the same--thanks al
old
04-17-2007 18:43:49
 Re: oil capacity for 860 ford tractor in reply to alan bane, 04-17-2007 18:18:48
I'll try and remeber to do that tomorrow.
