Tractor Talk Discussion Forum
ferguson 20 or 30
marvin
03-18-2007 12:50:16
hi all i just picked up a harry ferguson the nameplate says it is a 30 ,but the steering bracket has been changed, so where else can i look too see what i have, thanks marvin
Pajamafied John
03-18-2007 13:01:48
 Re: ferguson 20 or 30 in reply to marvin, 03-18-2007 12:50:16
If the oil filter is located inside the oil pan it is a TO-20. The TO-20 oil pan will have a circular plate and gasket on the bottom that is bolted in the center. Not the best design in the world but well....Also, as I recall the TO-20 engine will have a casting on the block starting with Z-120. The TO-30 will have Z-129. I have a TO-20 that has been a wonderful little tool. Tough little critter. Enjoy it
marvin
03-18-2007 14:33:41
 Re: ferguson 20 or 30 in reply to Pajamafied John, 03-18-2007 13:01:48
thanks for the reply,it is a 30 then the oil filter is on the outside of the motor ,also the engine number is 1750339m91 1211 the tag on the steering housing is to39261
anyinfo would be great thanks marvin
Jerry/MT
03-18-2007 18:52:02
 Re: ferguson 20 or 30 in reply to marvin, 03-18-2007 14:33:41
If the oil filter is external than the engine is a Continental Z129 and that was the TO-30 engine but the serial number is under TO 60001 so it's a TO-20 serial number. Me thinks you got a hybrid.
