Tractor Talk Discussion Forum
Hyd Cyl Rebuild
Jeff McBride
03-10-2007 20:40:48
Does anyone know a website to order rebuild kits for Hydraulic Cylinders?
Thanks
Jeff
Gerald J.
03-11-2007 09:25:43
 Re: Hyd Cyl Rebuild in reply to Jeff McBride, 03-10-2007 20:40:48
Baum Hydraulics, Omaha
Joe (Wa)
03-10-2007 21:49:30
135 Fan
03-10-2007 21:10:56
Most cylinders use common seals available at any seal retailer or hydraulic shop if you can't get original. Original usually work the best but aftermarket can work as good. Dave
Dick
03-12-2007 12:58:01
 Re: Hyd Cyl Rebuild in reply to 135 Fan, 03-10-2007 21:10:56
Hi,
While on the subject of Hyd. Cylinders. I have a question. When ordering the seals for a cylinder, what sizes do you have to have to order the seals?
Do you have to tell them the size of the bore of the cylinder? The size of the piston that holds the seals? Can you order the seals without taking the cylinder apart? Just wondering since I have some cylinders that need to be rebuilt and would like to have some information before I start.
Thanks in advance,
Dick
