Tractor Talk Discussion Forum
Axle shaft
Andy Z in Ct.
02-24-2007 13:39:15
I am restoring an Economy Jim Dandy and one of the axle shafts is worn. It was run without a bearing. I was thinking of welding it up with my mig welder and then turning it on my lathe. Will the heat from welding it change the temper or strength of the steel?
george md
02-24-2007 14:50:05
 Re: Axle shaft in reply to Andy Z in Ct., 02-24-2007 13:39:15
Andy,
Dave beat me with the right answer, spray
weld ( metal spray ) is the best way to go . Most cranks today are done with submerged arc
rather than spray.You will need to find a machine
shop that does repair rather than a production shop. If you don't find one in your area,send me a note , I have been spraying for 25 years.
george
Dave Sherburne NY
02-24-2007 14:20:26
Take it to a shop that has a spray welder, probrobly
a shop that does engine crankshafts .
flying belgian
02-24-2007 14:05:33
weld it with real cold setting. weld a couple beads than cool with water than weld acouple more. you need just enough heat so it sticks but you do not need to penetrate.
