Tractor Talk Discussion Forum
Case air cooled
Jim Johnson
02-18-2007 04:07:51
There is a Case air cooled engine on ebay(230091158619) I have never seen one of these. Wonder what they were used for?
Coloken
02-18-2007 04:26:02
 Re: Case air cooled in reply to Jim Johnson, 02-18-2007 04:07:51
They Used it on a small combine.
Most other makes used the wisconsin V4 air cooled.
Kennyp
2t2@ia
02-18-2007 13:56:41
 Re: Case air cooled in reply to Coloken, 02-18-2007 04:26:02
Later on, Case used a Wisconsin VE4 on the A6 pull type combine before live PTO was common. They worked pretty well, but were a bear to start when they were hot (if you stalled the engine or ran out of gas).
I can remember seeing one of the air cooled Case engines, though.
Jim Johnson
02-18-2007 04:31:45
How big were they?
Jon Hagen
02-18-2007 07:30:24
 Re: Case air cooled in reply to Jim Johnson, 02-18-2007 04:31:45
Those little Case air cooled engines were in the low 20's HP range, and from a small pull type combine. I repowered a Cockshutt 30 tractor with one of those engines 30 years ago. The Model 30 was only used around the yard for light work, so the lower HP did not matter. I loved the jet engine like scream of the cooling blower on that engine.
