$$$$$$$ Oil Pump $$$$$$$$$
Ray
09-21-1999 08:46:44
I'm getting together the overhaul kit for my Super C and was priceing a oil pump and boy did I get a suprise. He has one in stock for $350.00 and if he was to order one it would almost $450.00. Does these prices sound right.
John Taylor
04-20-2001 14:48:25
 Re: $$$$$$$ Oil Pump $$$$$$$$$ in reply to Ray, 09-21-1999 08:46:44
IS ANY ONE OUT THERE GOT A EATON PUMP FOR A bOLENS TRACTER WITH HYDROSTATIC TRANSMISSIOU MODEL 1886 01 OR 02 IF YOU HAVE ONE LET ME KNOW ALSO THE PRICE AT JCT@BRIGHT.NET OR CALL AT 740 474 6113 OR FAX ME AT 740 474 1331
Bob
09-22-1999 07:31:48
You can probably buy just the guts. You may only need the bottom plate and bushings.
HR
09-21-1999 21:01:36
Ray: I have seen a couple post over the last few months where oil pumps have been repaired\rebuilt by owners and worked out well.. It didn't sound too high teck for a handy repairman.. good luck..harvey
Dc Dale
09-21-1999 19:59:19
Nuthin' like captive parts!!! If it's any consolation , The oil pump in the popular 188 / 207 tractor engine is over $600!! and its still just 2 gears in a cast iron housing. Is yours actually worn out or damaged? Replaceing them just as preventative maintainence is mighty expensive. If you can, take it apart,check for wear, and reuse it if it looks good. Good Luck
