Tractor Talk Discussion Forum
JD 2755 Clutch
R. John Johnson
01-11-2007 11:55:52
Looks like its time to do the clutch on the old girl (AGAIN). The tractor spends most of it's life under a loader feeding round bales and I am getting about 4 years out of a clutch. Talked to the clutch rebuilder and he says we could put in a ceramic buttons. Claims this will greatly increases clutch life, but would be harsher to operate. Anyone out there with any experience/opinions?
Thanks in advance
John
CBBC
01-11-2007 15:49:31
 Re: JD 2755 Clutch in reply to R. John Johnson, 01-11-2007 11:55:52
We are doing my 2755 clutch next week. Last time it was done was 2 or 3 years ago. I think we used organic because it was more forgiving. Our tractor gets lots of daily loader work in manure and soil. Our guys do not treat the tractor well. I am just amazed they havn't done more dammage.
Grant
MSM
01-11-2007 13:33:27
A button clutch will give you alot more life BUT,there is no slipping the clutch to ease into a load,they are pretty much engaged or disengaged,if you do try to slip it it will tend to be real jumpy.Another negative is if you do try to slip it alot you will be replacing the flywheel at the next clutch replacement.The ceramic pucks are just as hard as the flywheel.
R. John Johnson
01-12-2007 06:56:32
 Re: JD 2755 Clutch in reply to MSM, 01-11-2007 13:33:27
MSM
That's the info I was looking for. If ceramic is that hard on flywheels, I'll steer clear of it.
Thanks
John
