Tractor Talk Discussion Forum
How do I clean the fuel filter on an old SW6 Inter
jmr2772322
12-31-2006 06:22:56
My tractore stalls after running awhile and I think there is a poor fuel flow. I don't know how to clean the fuel filter. It is an SW6 international 1953. There is a glass lantern fuel filter below the gas tank. I don't know how to clean it?
Thanks for any suggestions.
FarmallBob
12-31-2006 06:52:19
 Re: How do I clean the fuel filter on an old SW6 I in reply to jmr2772322, 12-31-2006 06:22:56
There should be a bail wire holding it in place. At the bottom you will see a knurled nut. Turn the nut to loosen the bowl, then you should be able to pull the bail wire out of the way to remove the bowl. At the top there should be a screen filter that may need cleaning. Also in the gas line going into the carburetor there should be a screen filter that may need cleaning.
Bob
RustyFarmall
12-31-2006 07:22:44
 Re: How do I clean the fuel filter on an old SW6 I in reply to FarmallBob, 12-31-2006 06:52:19
Might want to shut the fuel off below the tank before doing either one.
